Hi ,
I updated my Xcode and iPhone OS to 4.0 , SFS code is not at all working and it is giving the following error. In the Tic Tac Toe example, i got this error when i clicked on the log in button iPhoneSmartFoxiPhoneClient_TicTacToe[564:207] INFSmartFoxExtHandler:handleMessage msgObj:{
o = {
"_cmd" = logKO;
err = "Sorry, invalid credentials.";
r = "-1";
ANY HELP?
Updation of Xcode of iPhone
If you recently upgraded your iPhone’s firmware, it seems that it gave a bad effect on some of the applications installed on your phone. The recent upgrade or update may have corrupted the installations of the applications.
Do not try restoring your phone yet. Try uninstalling the applications that were affected by the recent update and then install them back.
This will put a fresh copy of the application on the newly upgraded phone. This will also help you know if the application is still compatible with your current firmware version or not.
If uninstalling and reinstalling the affected applications did not help, you may try restoring your phone to its factory setting. Or, you may consult with your phone’s official web site if there are also other users who have the same problem as you are.
