Dequan
Posted on - 11/05/2011
Hello! I just have a concern regarding my computer. At present I am using Windows 7. I wonder if there is any way to upgrade its 32-bit version to 64-bit version, and vice versa. Your answer would be highly appreciated. Thank you.
Upgradation of windows 7 from 32-bit version to 64-bit version
Hello Dequan,
I am sorry to say this but you cannot upgrade from windows 7 32 bit version to windows 7 64 bit version, you can only do installation of windows 7 64 bit version so as to remove the windows 32 bit files on your computer.
You will need to get a CD that has windows 7 32 bit version and install on your computer. You can get one from the internet. Make sure that you download a 64 bit version. Or you can purchase one from a shop nearby you that supplies software.
Regards
Mahesh Babu
gmac0612
Mahesh is right – Upgrades between 32 and 64bit versions of Windows are simply not possible. Why are you looking to upgrade from 32bit? It's usually because there is an app that needs a 64bit install to run, or you have more than 4GB of RAM.
It may be better to stay with your current setup if everything is working as expected.
Gareth
