Upgrade 40GB Teradata Express to 1TB
This is an installation Guide of Teradata Express 40GB to 1TB
First:
1. Download the latest version of VMWare Workstation
2. Download Teradata Express 40GB
3. Download Teradata Express 1TB
Tips:
For extra safety if something goes wrong when installing, copy or duplicate the files.
The installation guide:
1.Install VMWare.
  VMware-workstation-full-7.1.4-385536
  Download from www.vmware.com
  Restart PC twice (if you uninstall)
2. Open VMWare
  Open a spare copy (i.e. H:virtual-machines40GB Uncompressed1sles10)
  —Some people suggest bridged, others suggest NAT network. With Bridged I loose network all together as it sees my      Ethernet as down, so I chose NAT. Is this right?
3. Power On the Virtual Machine
  Note: The Powerup takes a long time the first time
4. Select SLES10 Operating system
  UserID : root
  PWD : root
  Welcome to your newly built SLES10 OS complete with Teradata!!!
5. Restart the machine. This is done as its a first time startup, get a feel for startup time
  Ctrl+R or VM>Power>Restart
6. Select SLES10 Operating system
  UserID : root
  PWD : root
  NB: we need to install VMWare Tools First
7. Select VM>Install VMWare Tools
  This will open VMWare Tools File Browser
8. Mount the cdrom
  Open Gnome Terminal and type
  mkdir /mnt/cdrom
  mount /dev/cdrom /mnt/cdrom
  The response should indicate a write-protected disk which is read-only
9. Uncompress the installer to the mounted cd
  cd /tmp
  tar zxpf /mnt/cdrom/VMwareTools-8.4.6-385536.tar.gz
  This step takes a while as it is a large archive to uncompress
9. Unmount the image and run the VMWare Tools Installer
  umount /dev/cdromÂ
  cd vmware-tools-distrib
  ./vmware-install.pl
10. Accept all default answers.
   The VMWare Tools has been installed previously
    Press enter to accept each default
   There are many defaults (around directories)
   Accept when vmware-config-tools.pl,Â
   runs after the installer file finishes running.
11. Networking on the virtual machine will be interruptedÂ
    To restore network type in gnome:
    /etc/init.d/network stop
    rmmod vmxnet
    modprobe vmxnet
   /etc/init.d/network start
12. Log out of the root account.
   Using the same gnome session
    xit
