Upgrade my pc to a gaming pc !
Building a gaming PC can be a daunting task… there are a lot of things to consider when answering this question.. First, your knowledge on PC hardware… assuming you know enough to build one…. It's as simple as finding the best parts you can afford that are compatible.. if you don't know enough… you can take a cheap class at most local community collages to learn enough to build a PC… Or… you can go to a local bookstore and get a How to build a PC for dummies book… or an equivalent… and self-teach yourself… I personally started by taking a junk PC.. and took it apart completely…and tried to put it back the same way..
To upgrade your computer to a gaming Pc, you need to consider a lot of things. First on the list is the graphics card. Look for a graphics card that is manufactured by NVIDIA GeForce or the ATI Radeon. Those two have the highest rate for gaming compatibility. Next to it is the processor. Find a faster processor so it can handle as many tasks as it can. Use at least 2GHz for gaming purpose. The third to consider is the Memory. Most of the latest gaming software requires 1GB of RAM. Try installing memory higher than the required memory space so you can run your game smoothly. And also, you will need 150GB hard disk space for saving your games.
You must first take note of the following requirements and which games you are into so you can decide which gaming system will fits you. You need to ensure that you will meet the minimum system requirements or exceeds the above requirements to avoid any trouble.
