kevin rith
20 points
Posted on - 08/24/2012
I’ve already installed flash player on my Windows 98 PC. I got an error that I need to either upgrade or install flash player as some websites required it.
I want to know which version of flash player compatible with Windows 98? Is shock player is okay for this case? Please help me to get rid of this trouble. Thanks.
Upgrade or install flash player as some websites required it
The "Upgrade your Flash Player" and "Install Flash Player" error messages are the default error messages as configured in the HTML source code. In general, it indicates that the linkage is inappropriate for one or more files that AMMAP supports. If you remove all the AMMAP files from the download package to the default directories you may not have any issue. Once you know how it works, you can do to shift things around and uphold the correct links.
You must have the subsequent files allied properly to the HTML file: swfobject.js; ammap.swf; ammap_data.xml; ammap_settings.xml. If you turn on Windows Automatic Update it will upgrade as per the requirement of its systems. I hope you understand it.
Since Windows 98 is very old OS and latest Adobe Flash Player which is probably 10 do not work with Windows 98. So you need to download and install Flash Player 9 which works fine with Windows 98. You can get Flash 9 from Adobe — Flash 9.
Also "Shockwave Player" works fine with Windows 98 and its browsers. You can get Shockwave from Adobe — Shockwave.
Hope it helps.
