Grace W
Posted on - 10/11/2011
Hello everyone!
I am experiencing a problem with an upgrade for Windows 7 64k. To be precise, I have tried downloading from Digital River official site and I'm just getting the same message:
We are unable to create or save new files in the folder in which this application was downloaded. please check the folder properties to make sure that you have security permission on the folder to write files and that the folder is not ready-only.
I would really appreciate any kind of support on this problem because I have already lost a lot of time coping by myself.
Thanks in advance.
lee hung
75 points
Upgrade of Windows 7 64k
Hi Grace,
Follow the following procedure and see if you can fix the error:
Using windows 7/xp 32 bit, download the 64 bit version of windows 7 professional upgrade.
Using the installer, extract the files.
Check the file size of the folder "extendesSetup and move it to root folder (C:)
Download the following file and place it into C:WINDOWSSystem32
Download Link
In the command prompt, type the following:
oscdimg -bC:expandedSetupbootetfsboot.com -h -u2 -m -1WIN_EN_DVD C:expandedSetup C:7.iso
 Download ImgBurn and use to burn ISO
Boot the computer, install your windows 7 64 bit and then activate it.
Try the above procedure and see if it works for you.
Regards
Lee Hung.
