Upgrade Windows 7 Pro To Ultimate.
Hey everyone,
I have Windows 7 Professional running on my PC, and I have the upgrade key also, but I don’t know how to Upgrade Windows 7 Pro to Ultimate.
I want instructions stepwise.
Hey everyone,
The process of upgrading Windows is very simple.
1) Open Control Panel.
2) Click on “Windows Anytime Upgrade”.
3) There you will see two options. a. Go online to choose the version of Windows 7 that suits you the best. b. Enter an upgrade key. 4) The first option lets you buy a better version of Windows and the second one lets you upgrade your windows using Upgrade Key.
5) Click on the second option and enter the key.
6) After that, Windows will install the upgraded features and ask you to reboot the PC.
Notifications
