Upgrade Without Facing 0x8007000d-0x2000c
Hello. I tried to upgrade my Windows but got stuck with a 0x8007000d-0x2000c error. Now I’m stuck with it and not aware of what should I do next? How can I make it work?
0x8007000d-0x2000c pops up when you try to upgrade from one window to another. The error caused by the driver bug check during the image applies. Before upgrading, always check that all the drivers have updated as well.
If the issue remains the same, then scan and restore operating file system health.
• Begin with opening command prompt.
• Type commands-
DISM.exe /Online /Cleanup-image /Scanhealth
DISM.exe /Online /Cleanup-image /Restorehealth
These commands will surely help in upgrading Windows.
