Hi all,
I just upgraded my laptop to windows 8.1 Pro x64. I have a Sony Vaio laptop,VPCEA1S1E, with an intel core i3 cpu and 4 GB of Ram. My main problem is that i can't find the latest driver for my graphic card which is the ATI mobility Radeon HD 4500 Series. When i open my device manager, i find two alerts under unknown devices. How can i fix this?
Upgraded to windows 8- no driver for graphic card
Hello!
I have also faced this problem because I have window 8.1 and my graphic driver was not update I go to this link and download all driver and check all the drivers.
Please visit this link and download the latest driver for window 8.
There are many drivers given in this link download all drivers and check one by one.
https://www.amd.com/en/support
If the problem is not solved the other way to solve the problem is below.
Download the Driver Checker And Update from the below link.
Install the Software in your laptop and run the driver checker and it will display the outdated driver just click the driver and it will install them automatically.
