johan weiz
20 points
Posted on - 02/15/2012
Hello!
I am facing a problem. To get some support, I tried to Javacool's website but found nothing. They are virtually empty and the problem I'm facing isn't exactly similar to the ones I'm finding on their site.
When I try to open the program Eulalyzer 2.0, immediately I find a runtime error 53 file not found "Armaccess.DLL" I think it ran well before upgrading to 2.0.
I just upgraded for the reason that 1.2 encouraged me to upgrade before it could read EULAs.
Please need your help. Thanks in advance.
Upgrading to Eulalyzer 2.0 caused Runtime error 53
I have a solution for your problem
Please download this file because it will be need for your problem to be solve
https://www.dll-files.com/armaccess.dll.html
Open the downloaded file extract armacess.dll to this location on your computer. C:windowssystem32
But if you are using a 64-bit version of windows, you should place the file to C:windowsSysWOW64
Overwrite any existing file and reboot your computer and Run the program and if it still occurs. Click start and then run and type this on the run regsvr32 armaccess.dll and then enter. And then run the program again this will surely work now. I hope you enjoy you’re stay here
If you install this application properly and you did not encounter any problems during the installation then there is no problem with the installation. Since you upgraded EULAlyzer from version 1.2 to 2.0, I think the manner or the way you upgraded the application is the cause of the problem. Upgrading an application without uninstalling it first, usually, is the normal procedure and doesn’t generate any error. But there are times that this doesn’t work. If the normal procedure in upgrading a software, where the old version is kept installed while installing the new version, doesn’t work and gives you an error during launch, uninstall the application completely. Then install again the latest version.
If version 2.0 is still not working on your computer, try installing the latest version of EULAlyzer. EULAlyzer 2.1 is already available and can be downloaded at http://www.brightfort.com/eulalyzer.html.
