Upgrading Samsung Galaxy Tab to Android issues
Hi Techyv,
After upgrading my Samsung Galaxy Tab 1000 to Android 2.3, I can no longer install another keyboard language.
How can this issue be resolved?
Hi Techyv,
Hi Chinronald,
Sorry to hear your problem. Don't worry because I have a solution for you. Take a look at the solution below and follow the instructions to be able to solve your problem.If problem persist, don't hesitate to message me back, I'll be glad to help you.
Make sure that you have read the instruction carefully because sometimes it is very fragile or sensitive. Good luck and have a great day!
-Zorian
Unfortunately, this feature is not supported in Gingerbread 2.3 but after a couple of updates you can avail the same feature once you have updated your Tablet to 2.3.6 Gingerbread.
If you do not want to update anymore, then you can use Go Launcher along with Go keyboard to have the same features. It is available free of cost in the Android Market.
It will provide you options like custom keyboard display buttons and languages.
Best of luck.
If you have a Samsung P1000 Galaxy Tab and you upgraded it to Android 2.3 Gingerbread then there’s no problem. The Samsung P1000 Galaxy Tab ships with Android 2.2 Froyo and is officially upgradable to Android 2.3 Gingerbread. Since your tablet is now running on Android 2.3 Gingerbread, the currently installed keyboard language app may no longer be compatible with the current operating system.
You need to uninstall it so as to also free up some space. Also, if you still want to install new keyboard languages on your tablet, the app you’ll be installing should now be compatible or support Android 2.3 Gingerbread.
The apps that you previously install on your device that are limited to Android 2.2 Froyo only are no longer compatible and you will not be able to install them back. If you want a keyboard app, try SwiftKey Keyboard.
It supports more than 100 languages including Arabic, English (US, UK, AU, and CA), French, German, Italian, Polish, Portuguese (PT and BR), Russian, Spanish (ES, LA, and US), and Turkish. Additionally, here are the specifications for your tablet. The Samsung P1000 Galaxy Tab is a 3G tablet operating on 2G and 3G network bands using GSM and HSPA technologies.
It was unveiled to the public on September 2010 and released on October 2010 but unfortunately it has already been discontinued. It measures 190.1 x 120.5 x 12 millimeters and weighs 380 grams. It uses mini-SIM card. It has TFT capacitive touchscreen display with 16M colors at 600 x 1024 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass with TouchWiz UI support.
It ships with Android 2.2 Froyo upgradable to Android 2.3 Gingerbread powered by Hummingbird chipset, 1.0 GHz Cortex-A8 processor, and PowerVR SGX540 GPU. It supports microSD expandable up to 32 GB. It runs on 512 MB RAM with internal storage available in the following capacities: 16 GB and 32 GB.
The primary camera supports 3.15 megapixels with LED flash and autofocus featuring geo-tagging and can record video in 480p at 30 fps. The secondary camera supports 1.3 megapixels. It has 3.5-millimeter jack; Wi-Fi 802.11 b/g/n with hotspot support; Bluetooth 3.0 with A2DP support; GPS with A-GPS support; and USB 2.0. It doesn’t have FM radio. It has built-in accelerometer, compass, and gyro sensors.
The preinstalled web browser supports HTML with Adobe Flash support. Java is supported via the Java MIDP emulator. It runs on non-removable Li-Ion 4000 mAh battery with talk time up to 28 hours on 2G and 25 hours 30 minutes on 3G. It is available in black and gray colors.
