Hello Techyv Guys,
As everyone knows, there are lots of online providers, that provide free mass distribution of any size of files through internet. Currently I am using google drive, through which I share files with my contacts. I request my Techyv friends to suggest the best provider that allows free upload file for mass distribution, also mention the features.
Thanks,
Coury Timmons
Upload file for mass distribution
Hello Timmons,
I will give you to software that allows you to upload files and I will also give you there respective descriptions.
1. The Ultimate file Uploader- this software allows you to upload multiple files with advanced support of upload photos. The main advantage of this software is drag and drop support. Click below to download this software.
http://www.element-it.com/multiple-file-upload/silverlight-image-uploader.aspx
2. The classic FTP file transfer software- This software runs on both windows and mac operating system, it also has a drag and drop function and the synchronized tool that checks local and remote folders for the most up to date copies of everything. Click the link below to download this software.
http://www.nchsoftware.com/classic/index.html
Hello
The best software is DropBox
You get 2GB free space for "free users" and your account can be upgraded at any time if you so choose.
You can share multiple folders between multiple people or one folder between multiple people etc.
When the files get altered in any way the files get updated on all the computers automatically.
If you do not want to share the folder but just want to send some files to someone else, you have the option of sending the other person a "download link".
They can then download the files but won't be able to delete or alter the files in the DropBox folder.
