Upload Portal Resource Error in JDeveloper
Hi! I created one Java Web page and now I am trying to debug this page but I received below error.
I can’t understand the logic of this error.
Please tell me the solution and also tell me how can I remove this error?
Upload of resource “newTestST” complete. Please check the log at the following location for upload status:
            C:DOCUME ~ 1rharveyLOCALS ~ 1 Temp upload_siteTemplate_17289.log
        OK
Answered By 590495 points N/A #121107
I think this is not an error. It is only an information dialog box informing you about the previous upload task that you did that was saved in a log file. Maybe you only misunderstood its content.
To further understand what the information is really all about, try reading the upload_siteTemplate_17283.log file located in this path: C:Documents and SettingsrharveyLocal SettingsTemp. If you think that this is really an error, if you have a disk utility application installed on your computer, run it to check your hard disk for errors.
  1. Right click on drive C and then select Properties.
  2. Click Tools tab.
  3. Click Check Now.
  4. Check Automatically fix file system errors and then hit Start.
