Uploading files- OpenRequest failed error message
Hello! I am using Webplus which is a website design software, I just uploaded my files to my website server and something went wrong. I uploaded my files in a usual way of uploading, but I don’t know why I got this error.
I contact the technical support of my hosting company, and they said all was fine on their side, so maybe the problem is in my side. Please help me about this one, I tried all the things that I know will help me about this but nothing solved my problem.
Please help.
Uploading files
There was an error operating remote file ann-battenfield.html for writing.(OpenRequest failed)
Answered By 75 points N/A #116906
Hello Julius Cane,
Are you getting this error for all the files that you are trying to upload or only a certain number of files? The problem could be occurring because you may be saving the website to a different folder on the computer which does not have the local host settings. You should make sure that all the files that are trying to upload are accessible from the local host folder on your computer.
Otherwise just try saving the files and the close the web plus application and then start it again and see that will solve the problem.
Hope this helps.
__
Regards
Lee Hung
