Urgently Need To Buy Hp Printer Ink 92 93 At Discount..
Searching for a new cartridge 92 93 for my hp printer. Where can I buy the same at a discounted rate? I have heard online shopping is more beneficial for the same. Please help.
See the price will entirely depend upon the kind of cartridge you want to buy. If you wish to buy a simple black one then it will not cost you more than a couple hundreds but if you want to buy a coloured cartridge, it may cost you triple the amount than the simple black one. Further, whether you want to buy from the authentic store or from any other seller, that will also determine the rate. I suggest you buy it online from Amazon, etc. from any other seller. You can find the same below
https://www.amazon.in/gp/aw/s/ref=nb_sb_noss?k=hp+ink+92+93
Hope it helps..
