Berna
20 points
Posted on - 08/08/2011
URU 4000 Finger Print Scanner Saving Data
I am planning to develop a Time Keeping system which I use URU 4000 Finger Print scanner to verify time logs. Any one here can give a little snippet of the code in Visual Basic 6 about reading, saving and verifying finger print from this device. Your help is much appreciated.
Before start programming to the scanner you must have installed DigitalPersona One Touch Software Development Kits (SDKs) in the computer.
There will be two versions of the SDK, and for your task it will be enough having Free Software Development Kits (SDKs). You will find example projects also there.
You can download and refer to solve your problem,
And if you want more on help URU technologies you can visit their URU developer center or register in their developer forum Download Link 4.
And you will be able to find out some sample coding s relevant to your matter from Download Link 5
