A USB connector from a laptop screen to avi source
Hello techyv.com!
I have here a laptop and a TV. I want to connect my laptop into that TV for a larger screen, but it doesn't have a projector connector only AVI, on the other hand my laptop doesn't have an AVI port only a projector port. So is there a usb connector from a laptop to avi source?
Answered By 0 points N/A #170691
Hi, sometimes our computers and laptops are portable and versatile, but sometimes we need to share things from our laptop with another computer because the screen is small or for some other reason. All you have to do is to hook up your laptop to the TV, and you need to determine the video output of the laptop and then see where the video input of your TV is, and then get the right video cable to connect laptop to the TV. If it is necessary, you have to obtain an audio cable. You also have to shut down your laptop, then connect the video cable to your laptop's and TV's video port.  Next, set your TV to the input coming from your laptop. Now, turn your laptop on.
