USB does but Wireless printer is not working
Hi all
I receive the "Printer not responding" error message when I start to print. Just the once I hooked it in USB port it started to print (Under a different printer name (copy1)).
What is the reason?  I do not recognize what varied on my end that unexpectedly it closed printing wirelessly. Regularly I don't print.
Then I went all over troubleshoot and found it like default printer as well as printer sharing.
After that I disabled my Anti Virus.
So, i need a solution to solve it. I need your help. Please. Thanks.
Error: Printer not responding
Answered By 0 points N/A #140688
Hello there buddy
First of all you should specify what is the model of your printer and where do you use WiFi connection on the other computer or the wifi of the printer itself. Well buddy if you are using 2 computers and the other computer is using wifi you should first share the network for both computers and in the control panel in fax and printer sharing browse for a local printer attached to the other computer. Then specify the name of your printer and share it to your network.
Well if you are using wireless printer you should modify the settings and define the lan ip
Hope you get something about this answer
Have a nice day.
