USB Driver installation problem for Eval Board Eval-ADF4150EB11Z
I have recently bought an oval board for ADF4150, which is Eval-ADF4150EB11Z; but I facedproblem to run it. It wasn’t getting the USB driver installed. I found the board CY768013 for the USB drive.
I got the USB driver updated and installed through the communication with Cypress.
But when I got the power on, the interface was still indicating “no USB.
The error message is attached here for clarification.
ADF4150 – USB ERROR
ERROR 1001 NO DEVICES FOUND
OK
I need someone to solve this issue.
Please help me to solve it.
Answered By 0 points N/A #147566
The DABmate M1+ is a USB device with a simple aerial, approximately 340mm in length. It's fairly small, at 85x40x15mm and the aerial is telescopic and can be folded to the side of the device which makes it very portable. In areas with poor reception, the aerial will be a weakness. The specification says that the aerial connector is an SMA connector, so perhaps the aerial can be disconnected and replaced with a stronger aerial?
The device is supplied with a USB lead while will allow connection to a PC, or the device can be connected, without lead to the side of a laptop. Many Bluetooth or wireless dongle operate in this fashion, however, in this case, sticking the aerial up will likely restrict movement, so use of the lead is advisable.
Ganeshwar
