Hi
I have bought a new USB headset to my little sister’s laptop. But the sound is very low and in a bad quality. I need to know is it possible to improve the quality and the sound of the headset by using the usb equalizer drive
Thanks
Is USB equalizer drive can improve the sound and the quality?
Yes it is possible to improve the quality and the sound of the headset by using usb equalizer drive. One of the usb equalizer drive functions is producing a low noise and giving clear sounds. Usb equalizer drive is more wanted now regarding to the great range of audio capacities out there on media things.
Best regards,
Heather marie
1. First of all open Playback devices settings from sound option in control panel.
2. Select your USB Headset, and then open the Properties.
3. Open Levels tab, and then click on the Balance button.
4. Finally slide one of the sliders there making sure that the values are different, for example top at 100, and bottom at 99.
This might solve your issue.
