blackjan
Posted on - 10/09/2011
Hi
My REDDATA USB 4g USB not recognized or not detected. I plug my USB in pc and the display messages come Found a new hardware. I close the display messages Then my USB is not recognized in my pc why?
There is a problem about my USB or what?
Please some one to help me….
Thanks
blackjan
rabin
USB NOT DETECTED OR Unrecognized
Hello Blackjan,
 Your USB is already damaged from harmful viruses. Everytime you are using your USB no matter the how much the memory is 1G, 2G or 10G still it wont be exempted once a virus falls on that USB.
Once you are using your USB keep scanning and then after doing something copying or sending files to USB, Be sure you have safely remove that is located right corner bottom near the system Date and Time.
Once you are abusing it unplugging the USB from computer without proper safely remove might damage your USB life span.
Nowadays USB are sensitive when a computer that inserted has a virus and can be damaging all files inside the USB. So better scan and remove it properly.
Your USB is already a junk and you need to buy a fresh one.
Thanks,
Rabin
snapted
10 points
Hi..
just try another option, Try to connect to another PC, if it can works on another PC, so it means your USB disk is ok, and the problem is on your windows software, maybe damage or something, simply try to reinstall your windows, maybe it can solve your problems.
If your USB disk doesn’t work when attached to another computer, it means your USB Disk has some hardware problem. Maybe it’s time to get the new ones.
