USB Toaster Hub & Thumbdrives
I think of using a USB Toaster Hub & Thumbdrives. But I'm not sure that do I have to buy two things combined or I can buy it separately? Which brand is better to buy?
Dear User,
You can buy Thumb Drives, flash drives, without the need of a Toaster multi USB connector. As long as you have a USB 2.0 port on your computer available you can use a Thumb Drive without any extra purchases. The Toaster Hub is a device used to plug in multiple Thumb Drives into. Not needed unless you need to add more USB ports to your setup.
My favorite brands of Thumb Drives, Flash Drives, are:
1. San Disk
2. Patriot
3. Lexar
All three are reasonably priced and work well. I use them all the time.
Thank You.
I think you are referring to the product called “USB Toaster Hub and Thumbdrives” which you can find at ThinkGeek: USB Toaster Hub and Thumbdrives and on Amazon: Toaster USB Hub – Silver. Unfortunately, they are no longer available for purchase. The item is composed of a USB hub and four USB thumb drives. The USB hub has four USB 2.0 ports with speed up to 480 mbps.
It includes 1-meter long USB cable as well as an SD card reader. The hub is available in silver color. The four USB 2.0 thumb drives have 4 GB capacity each and even have their own name according to colors. The white thumb drive is called “Tato”, the yellow thumb drive is called “Butta”, the tan thumb drive is called “Ry Ry”, and the brown thumb drive is called “Crisp”.
Each thumb drive measures 1.5 x 1.25 x 0.75 inches.
