USBDM – Target Vdd Supply Interrupted
200 points
Posted on - 06/22/2011
Below is the screenshot.
I have an error message that comes as such. “USBDM – Target Vdd supply interrupted. Please restore power to the target. Retry connection?”
This error message came up when I was working on CodeWarrior and i just completed installing a few sample codes. I have a Windows XP operation system. I normally use Code Warrior 5.0 and USBDM v.4.4a to interface.
I have tried it on a different computer. Failing which, I tried to reinstall the drivers. Yet I seem to get the same error message. Still the code does not seem to work.
Do you know what seems to be the problem? If there is anyone who has had the same issue, can you please tell me how to work around this issue?
Thank you!
