Use of craft keys to connect direct zip
I am going to start my bulk files merged in a zipped file to make the secure transformation. But most of them are confidential and secrets. How can I make craft keys to connect direct zip file?
Hi Aabel! First and foremost, please do download WinZip and install it. You can download it for free by just typing it in Google search.
(This is only for Windows Vista below. If your OS is Windows 7, please refer to the instructions after this)
After installing WinZip, please go to the folder where your files are.Â
1. Right click the folder and add it to WinZip.
2. Press Ok, And then Password.Â
3. Enter your desired password.Â
To add other files, just open the Zip file and click Add.
For Windows 7, you have to have the full version in order to put a password in your files.Â
