Use of Last Known Good to recover computer
Last Know Good Configuration is use not to recover your system but to restore it from the last date where it worked fine or before any issues started. It is different from system recovery which is bringing back your computer to its original settings just like when you first bought it. Usually, we use Last Known Good Configuration if:
Use this command only when system start troubling like, frequent hang, start getting shutdown sometimes automatically, speed gets too slow . Do not run this command again and again.
Hi Dear,
Last Good Known settings are very impressive facility in windows 2000 to Windows 8.
It is used when you are unable to work with computer, Windows did not boot, some kinds of errors are generating by itself.
On these conditions you can use "Last Good Known settings" these settings are stored in computer as a restore point.
If you want to do so. Then press F5 key at the startup of computer after the logo of manufacturer.
Than there will be list of Recovery options appeared.
Safe mode.
Safe mode with command prompt etc.
You have to choose "Last good known settings" here.
Your computer will restores some settings and windows will run properly.
Thanks
Notifications
