m raju
Posted on - 07/27/2016
Hey everyone,
I have learned to Convert PDF Files to Excel using Acrobat Reader and the Export option. But, now, I want to Convert PDF File to Excel Spreadsheet using an online tool only. Can anybody help me with it?
Use An Online Tool To Convert PDF File To Excel Spreadsheet
It is easier to perform the Conversion of the Documents online, instead of Converting them manually. You can use PDF Converter Tool to perform your task.
Visit https://www.freepdfconvert.com,, and select the “PDF to Excel” option.
Click on the “Select File” button to upload the PDF File that you wish to Convert. Step two is to choose the extension. Select “xlsx” from the Drop-down Menu.
You will find a “Convert” option, click on it, and you will find your transformed file.
