shaheen
20 points
Posted on - 07/12/2011
hi,
I want to use other person computer without his permission please tell me its solution.
First read question carefully then give me answer.
Use other person computer without his permission.
Only if you have its personal experience then give answer. I give you Good points if you give me proper answer.
Thanks
Scot1984
15 points
Of Course you can access the different machine of the same network without their permutation. But you should have a minimum of administrator rights. If you want this to be done without an administrator there is solution which I have come across, please go through the fallowing information to do so,
1. Click Start, click Run, type regedit in the Open box, and then click OK.
2. Locate and then double-click the following registry subkey:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlLsa
3. In the right pane, double-click restrictanonymous.
4. Make sure that the value in the Value data box is set to 0, and then click OK.
5. Close Registry Editor.
6. Restart the computer.
