Useful & Improved DiskDigger 1.5.2.1312 Software
The latest arrived recovery software DiskDigger 1.5.2.1312 is very effective.
Will it run in Windows vista?
Yes DiskDigger will run on Vista. But you need Microsoft .NET Framework 2.0 running on your system. DiskDigger is a smaller, independent utility which recover lost, harmed, and erased records from any media of your PC. This includes numerous sorts of memory cards, USB drives, pen drives, hard drives, floppy, and optical drives.
 It hunts down traces of records as well as erased records and enables you to view them as they are found. You are able to limit the search to certain document types and in addition specify the segments which you wan to scan. However it’s not a repair utility, it’s simply an astounding file rescue tool.
System requirements:
Windows XP/ Windows Vista/ Windows 7
Microsoft .NET Framework 2.0 or higher
The version of DiskDigger you posted is the older version of the software but is still very effective in recovering accidentally deleted files in your computer’s hard drive. The latest version as of January 25, 2013 is DiskDigger 1.5.5.1477 and you can download it from Brothersoft DiskDigger 1.5.5.1477. This piece of software is priced at $14.99 but you can also download it for free though I’m not sure of its limitations if you are planning to use the free version.
This new version supports Windows XP, Windows Vista, Windows 7, and Windows 8. This application is used to undelete and recover lost or deleted files from any types of media such as the memory card, hard drive, USB flash drive, and many others. Even if the storage media has already been formatted, you can always recover the files it previously stores. You can undelete or recover files from different file systems like FAT12, FAT16, FAT32, NTFS, and exFAT.
