Useful UNIX Networking commands for routing
What are the most common and useful Unix networking commands for routing? What is the best way to familiarize myself in its functions and usage?
Dear friend,
route – Show manipulate the routing table (it comes with many options)
netstat – network status command.
Ifconfig – network interface command.
Ping
telnet host
telnet ip-number
netstat –r print routing table
route…params setting a static route path in routing table
routed – used for dynamic routing
gated – it used the OSPF, EGP and RIP protocols.
traceroute- used for tracing route of IP packet.
Arp – print the Arp table.
NFS/NIS – network file system
The best way to familiarize yourself with above and other more Unix networking command is to practice each and every command of networking with as many option as possible and try to understand it practically if you know about networking concepts and protocols.
