User friendly Notepad++ Portable 6.1.3
The newly arrived Notepad++ Portable 6.1.3 is very helpful in programming. Is there any way of running this inside of flash drive rather not copying it into the computer?
Yes, you can download the portable version of it here. Portable simply means that you can run this application without installing it. So, this application will not have any effect on the registry record in Windows OS.
You can carry this application in an external drive and run it directly on any PC.
Notepad++ has features for saving your sessions, carry out mouse gestures utilize the hotkeys and many more. You can also emphasize the syntax, activate auto-fill of words and functions along with which several exploration operations are available.
It utilizes very less system means and also includes a thorough walkthrough file and incorporates a user-friendly UI which makes it magnificent for coders, in particular.
However, please go through this link to know more about using portable apps safely”
Notepad++ is a free source code editor and can be used as a replacement for Microsoft Windows Notepad. It is distributed under the GPL license or the GNU General Public License. It runs only on Microsoft Windows. Also, the developer of Notepad++ urges the users to translate the program into their respective native language in case the program is not available in their language.
It is written using the C++ programming language and is build on Scintilla, a powerful free source code editing component. Notepad++ guarantees higher execution rate and lesser program size because it applies pure Win32 API and STL. You can download the regular version from Notepad++ 6.8.6. Since you want a portable version of the program, you can download the portable version from Notepad++ 6.8.6 Portable.
Take note, the regular version requires a complete PC installation while the portable version doesn’t. You can copy the portable version in a USB flash drive and open it directly from there on any computer running on Microsoft Windows.
