User is not able to open the doc lib in explorer mode.Why?
There are a number of directions that papers can be got at in SharePoint. One technique is to exposed the document library in windowpanes adventurer aspect.
To do this, merely click on the document library you prefer to open, then go to the “View” sink menu and choose “open in adventurer view”. When adjudicating to open up in Windows adventurer view from a windowpanes host 2008 machine however, you may get the observing substance; “Your customer doesn't support affording list with Windows adventurer”.
This is induced by the Web customer service not running.
To adjudicate the issue, run the “Add boast Wizard” and choose and establish the “Desktop Experience” boast. Then, loose the services comfort and you should see the Web customer service is carrying. This will adjudicate the effect and you should be capable to open your chosen papers library in adventurer view without any effects.
If this is the first time that this happens, try restarting your computer then try it again. See what happens after booting the machine again. If this did not solve the problem, you may try doing a clean installation of the program to fix any corrupted files that may have developed in the system. Uninstall Microsoft SharePoint then restart your computer when asked.
After booting, check your computer for any possible errors. Use a disk utility application to check the system. For a much thorough diagnostic test on your machine, use disk utility applications like Norton SystemWorks, Norton Utilities, or PC Tools Performance Toolkit. Install the software again then check if this fixes the problem. If this doesn’t fix the problem, try visiting Microsoft’s website to find a better solution from their support page. Or check the software’s Help menu or section for an immediate possible solution to the problem.
