Using multiple operating system in the same pc
I need some information. Is it possible to use multiple operating system on the same PC. If possible then will it affect the PC? How far the effects will be applied?
Is it beneficiary for the user? Please let me how it works and then give me some instruction about which operating system will be best for combination.
Dixon Chapman
