Queries on using BARedit and Ultra DMA
Good day to all of you. I tried tweaking my UX a little. I did not realize that my Mton SSD is an ATA-7 hard drive. I exchanged it with my UX280 and then tried hdparm to view ATA hard disk hardware parameters. The sequential reading speeds went from 73MB/s to 93MB/s. And then, I opened BarEdit to check if I can increase the writing speed. The current sequential write speed is 52MB/s; the average level is 75-80MB/s. On BARedit I went to Bus0Dev31Func1 (Intel IDE controller) – Offset 054. The bit value that was there is 00001011. I assume that is for udma 5, as my UX490 Samsung SSD (udma 4) has a different value of 00000011. I set the value to '11' on for mtron & write dropped to 37 MB/s, about the same as the Samsung. I am asking anyone who knows how to correct bit value for udma mode 6. And if anyone has a native udma6 drive. Thanks a lot
