hugh barre
10 points
Posted on - 10/04/2012
Is it possible to archive a remote access to an iOS ipod using another iOS device with a different version of Tango remote control music player and still enjoy the same control speeds and efficiency?
Using different versions of Tango to archive remote access to iPod
Hello Hugh,
I guess it is possible for the two iOS devices to be paired together as long as they have been configured to access each other. A remote access for the devices can be done either wireless or you can connect them using a cable. Therefore just try a method that you're comfortable with.
Nicke
Hi Hugh,
It is possible to have remote access to the device through Tango software.
The steps to perform the operation are as follows:
1) Download and install the Tango remote control media player from the iPad official website
2) Install the application on the iPod Touch and iPhone device
3) Open the application on the device where the music is to be played
4) Open the application on the device that will be controlling the other device
5) Follow the different functions and the required functionality is achieved
