Using the feature of excel envelop curve
I not new at Microsoft excel, but each time I want to make an envelop curve feature, I don't know what to do,
Please help me
Please help me
I’m quite confused with your problem. I think the envelope curve feature that you are saying is from a different application like Adobe Photoshop and not in Microsoft Office Excel. But if you think your software seems not working properly, try restarting your computer then try it again. See what happens after a reboot.
You may also try reinstalling Microsoft Office Excel to replace your present copy of the software. Uninstall Microsoft Office Excel then restart your machine when asked. If this program is part of the Microsoft Office package installed on your computer, uninstall only this feature and leave the rest of the applications installed. After booting, check your computer for any possible errors. Use a disk utility application to check the system. Install the program again then see if this fixes the problem.
