Hi all, I am an iPhone user and right now I am using iPhone 4s. I have been using this phone for quite a long time now. I recently upgrade it to iOS 7.1 I was thinking if my phone could support the fingerprint sensor. Is it compatible with iPhone 4s or not? Thanks in advance for the help!
Using FingerPrint Sensor on my iPhone 4s
We can still install Touch ID application with IPhone 4s.
Touch ID is one of the best option that you can use. Using biometric systems you can use your finger print as your password and only can access it. You can use also your Touch ID paying or processing payments. You can shop online, choose any item and use finger print for authentication. Touch ID doesn’t store any picture of your finger print. It will just install bunch of codes and arithmetic explanation that points out to the uniqueness of your finger print. You have the ability to add finger prints that will only accept by your phone.
