Is it possible to use my gmail.com account with the email option in excel having been set up for outlook express? The reason I am asking this is because whenever I click on the email icon in excel an option box appears with the following options: 1. Send the entire book as an attachment 2. Send the current sheet as the message body How can I remove this box? I need your assistance.
Using Gmail account with excel email option set for outlook express
Hi Lauren,
Yes you can, it is possible to configure your Outlook Express to GMail Account. Just follow below procedure;
Open your GMail Account then click the settings in upper right of Navigation bar.
Just click the tab marked Forwarding and POP
Then check enable POP for all mail you will received now on.
Then click Save Changes
Go to your Outlook Express, then click the Tools menu and select Accounts
Go Type your name and click Next
Then Enter your Gmail address and click Next
Go to "My incoming mail server is a [dropdown box] server, then select POP
Go to "Incoming mail server," then type pop.gmail.com
Go to "Outgoing mail (SMTP) server," then type smtp.gmail.com and click Next
Go to "Password," then type your Gmail password and click Next
Of course you have to configure a new account,
Just highlight the account name and click Properties
Then Click the Servers tab
Go to "Outgoing Mail Server," while ensure that the following is checked: My server requires authentication
Then click the Advanced tab
You need to ensure the following is checked under both "Outgoing Mail (SMTP)" and "Incoming Mail (POP3): This server requires a secure connection
Go to "Outgoing Server (SMTP)" then type 465
Go to "Incoming Server (POP3)" then type 995
Now click Apply, click Okay and close.
Hope this help.
Best Regards,
A.Wright
