Using ios audioconverter aac for its screaming
Can ios audioconverter aac stream be replaced by any hardware encoder to make the AAC stream? Or I just need to use that to encode my video in x264? The problem is I would like to clean my hard drive because it got some slow and I need the audio converter which is smaller than the one which is ios audioconverter. Thank you!
Answered By 40 points N/A #133197
I found this application which is perfect for you:  https://www.zamzar.com/convert/wmv-to-aac/
This application is very popular and top-rated.  To use it, you need to input the audio/video files which you want to convert, then select the output folder and format, and, lastly, click on the “Convert” button. After the process is finished you'll have a converted file.  I hope I helped.  Regards
