Can anyone help with this?
I am using JQuery and PHP to run a webmail script for my website. The problem is that I can’t compose or even reply to the mails using WYSIWYG editor.
I already tried some things that might help me but unfortunately, no luck.
jhon12
Using JQUERY and PHP webmail script, but can’t reply to the mails
Hi Rosa
This may be a problem of your script which is not allowing you to compose and rely the mails. Although WYSIWYG editor is very power full. May be it might a problem with your Browser. did you try it other browsers too?
Any why my suggestion is that you should use Mercury editor which works fine with all browsers. and the best quality of mercury editor is that its shows a full page email editor.
It supports in previewing content before sending mails and also support the spell checker. It is best tool that ever use.
So just try the Mercury Editor it will solve your problem. i am sure
Regards
Jhon
