Using jQuery for mobile lightbox?
Hi Andrewjohn,
You can easily use a light box with your images using the various lightbox plugins available on the internet. These plugins can directly use in code and will work after minor image path change as per your specific requirement.
You can go to the following links –
Choose any of above, and use as per your requirement.
Happy Coding.
Narthon
If you are new in creating programming codes and or scripts and you want to learn how to create program codes and scripts using jQuery, then W3Schools will help you. jQuery is a JavaScript Library that greatly simplifies JavaScript programming and is also easy to learn.
Besides jQuery, you can also learn other jQuery commands such as:
To learn more about it and to start your online tutorial with jQuery, do visit W3Schools.net | jQuery Tutorial.
Notifications
