Using Laptop without a battery
Hi! I was using my laptop and it got overheated, it always is showing this problem after I use it for a longer period of time. So it was continuously shutting down automatically. So I plugged out the battery and started using it on direct electricity and obviously it works. But is it safe to use laptop like this on regular basis or should I make sure that I use it through the battery?
