Using Mac spoofing mobile devices to hide identity for ease of access
How does one utilize mac spoofing mobile devices in order to hide the mobile device's identity for the ease of access of certain restrictive content both online and phone applications?
Best Answer by Riley weaver
Answered By 10 points N/A #146011
Hello joanna,
This is a special technique used by so many users who change their mobile devices MAC (Media Access Control) address and try to get access in the network and also do this to use some applications. You can do it by having some special scripts or there are some android software is available which can help to do this. I don’t want to talk about the script because you may get so many scripts on so many websites but most of them do not work properly (as far I know). For some android set you can browse in this link:
http://www.appszoom.com/android_applications/mac+address+change
There are some companies which use symbian as operating system. I looked for any software which can do anything like that, but did not get anything.
Thank you,
Riley weaver
Answered By 0 points N/A #146013
Hello there!
As far as I know changing or spoofing a MAC address is possible yet not an easy task it actually requires a lot of things. To be able to do this you may have to have a low level access to the hardware, which can be done in OS level. You will also need some scripts or write a library which can be used by Java. I can’t really give you the script but you can find these on a lot of websites. One more thing MAC spoofing may be or not be illegal depending on how you use it so use it wisely.
Goodluck!
