Finlay 50 points N/APosted on - 07/09/2014
I use Macrium for back up. When I create an image of the 'partitions required to backup and restore Windows', does it include all the programs on it? I've installed several freeware, I have a lot of documents and photos, will it be included? I just want to play it safe.
If the backup refers to an entire partition like in this case, the partition to backup is referring to the system partition which is drive C by default, the backup will include all the programs installed on your computer.
If you are backing up your system partition to another separate drive, check the total size of your system partition then check if the available space on the other drive is bigger than this amount. One partition refers to one drive. To check the total size of your system partition, open Windows Explorer then select “Computer” on the left pane.
Next, on the right, click on drive C first to select it then right-click it and select “Properties”. In the “Properties” window, in “General” tab, the amount indicated in “Capacity”, in GB, is the total size of the drive or the partition.
Partition or drive size
Once you have the total size of the partition to backup, go to the backup drive and check the amount of available space and make sure this amount is higher. If you haven’t updated yet to the latest, download the latest free version of Macrium Reflect. The latest version at the moment, Macrium Reflect 7, supports Windows XP Service Pack 3, Windows Vista, Windows 7, Windows 8.x, and Windows 10.
For servers, it supports Windows Server 2003 Service Pack 2 and higher. It requires 512 MB RAM. Supported file systems include:
FAT16
FAT32
NTFS
Ext 2, 3, and 4
Note: all other file systems and unformatted partitions will be imaged on a sector by sector basis like for example, every sector in the partition will be copied.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
