Using Microsoft Management Tools On Windows 8.
I want to access the Management Console in Windows 8, but fail every time miserably in between the steps. How can I use Microsoft management tools on Windows 8 for better efficiency?
To access Computer Management Console, go to the extreme left lower corner and use right-click to choose Computer Management. There are many tools which can be used to tune up your system. System Tools contains the Task Scheduler, Event Viewer, Shared Folder, Device Manager, and Performance. You can expand any of them to repair the desired properties. Storage helps you to manage the disk space with the Disk Management. The advanced settings ensue from Service and Applications.
