Using Microsoft Office On Mobile Smartphones For Android
Hi. How do we start using Microsoft Office on mobile Android smartphones? Is it free to use? What are the options available for users?
Hey. Yes, there is a provision to use Microsoft Office on mobile devices. Microsoft has made the whole process easier, and you can get the download links via message or on your email. The user can request for the link using the following link:
https://products.office.com/en-us/mobile/office-mobile-apps-for-android#Send
Also, users can download directly from the Google PlayStore.
The app is designed to have all the features of the Office on PC. Further, it is enhanced to suit the touch features of modern smartphones. All the files once used or also stored in the cloud, and there’s no trouble about saving them. It is one of the more efficient apps which has transformed from the PC to the smartphone.
If you want to use Microsoft Office applications on your Android phone, download Microsoft Office Mobile. It requires Android 4.0 Ice Cream Sandwich and higher. And yes, installing it is free. It allows you to access, view, and edit your Office Word, Office Excel, and Office PowerPoint documents directly on your Smartphone. The app also allows you to open and edit Office documents attached to email messages.
All three Office applications have been optimized for the small screen of your phone. When you edit a document, the content and formatting remain intact. Aside from opening and editing existing Office documents, you can also create new Office documents with Office Word and Office Excel. If you want to install the Office applications separately, download them from the following:
These three Office applications on the list are the latest and replaces Microsoft Office Mobile. All three applications require Android 4.4 KitKat and higher.
Notifications
