Using msconfig to increase the speed of working of computer
I have heard that the utility named Microsoft System Configuration Utility, or simply msconfig, can be used for increasing the speed of computer. Have you any ideas how to do that, moreover, I will be very thankful for any video lessons about this, for example, on YouTube.
Answered By 30 points N/A #171292
Hello Dear,
You have heard very true. The Microsoft Configuration utility is good and you can make your PC's performance better with the help of it.
Type msconfig in RUN and press enter.
Microsoft configuration utility will open. Click on startup tab and you will see this window.
Remove ticks from all unnecessary startup files.
Then click on services tab and then you will see this window.
First click on hide all Microsoft services, then remove ticks from unnecessary services.
Now click on Apply and OK.
Restart the computer and enjoy.
Thanks
