I recently bought D-Link 2750u DSL Router from Flipkart. I noticed a USB port at its back. The USB Port is colored blue from inside. I use to charge my phone through this port but I was wondering if I could put my 3G Net Setter into this port and Route SIM Data through WiFi of this Router. Is this possible. Please Guide step by step.
Using Net Setter in USB port of my Router
Using Net Setter with DSL Router may be possible or may not be. We can't say this thing with completely confirming it unless we know the device supports connection through Net Setter.Â
Many Routers does support this kind of functionality that is connecting Net Setter with router, but you can see if it can connect by reading the manual that came with your router device. Also you can confirm it on the site you purchased it by looking into it's features.
Once you confirm the complete details about the device connectivity we can help you out with rest of the guide to connect the device.
