I need to get full read and write access to Windows partitions under Mac OS X with the same high speed as native HFS+ files accessing to NTFS, regardless if the files are located on the Mac’s HFS+ formatted volume, or in Window’s NT File System. Can it be done by using the paragon gratis mac? Please suggest the best way.
Using paragon gratis Mac to access Windows partitions under Mac.
Hello Margaret M Griggs,
As it is a best software if you want to get full access to read and write to windows partition under mac os. You can download it from the given link below.
 If you had installed bootcamp you should be able to access the files in windows partition in read-only mode. Further OS X can copy files from the Windows partition but does not allow to write to it. For that we need third party software like Paragon that you have mentioned. Paragon is a good choice, my other recommendations for you would be:
One another recommendation is that, before you install the drives, try Macfuse, an easier way to manage your file systems with different mountable drives.
1....
