Dear friends
I need to know how I can use my Relaince Net Connect and also connect more than one computer to it. I also have a Wi-Fi enabled Laptop and want to use the Internet Connection on it. Is there any method by which I can use the internet connection on the Desktop as well as the Laptop using Wi-Fi Connection?
Thanks
Using Reliance Net Connect more than one Computer
Actually there is no such System available for connecting a single modem to multiple devices. A Modem has a single IP address. However it is possible if you get a LAN collection between two machines and then you connect the server to the Modem so that both of them share it. Another way is to connect a computer remotely to another computer and then use the computer connected to the internet using the remote machine. The remote connection may be made using cable or blue tooth as preferred. You may buy a router to link both the computers.
Actually the requests from two different IP’s are to be routed through a single IP of the Modem. That is why a router is essential. Else the above said remote connectivity.
