Using Server 2003 and Windows 7
My Server runs with Windows Server 2003 and there are up to hundred clients which all runs with Windows XP. Some of the client computers are replaced and the OS for the replaced system is Windows 7 only.  It is loading printers & network shares. But it is not loading a roaming profile which is available in the Windows XP. I think it may not be compatible to run Windows XP and Windows 7 computers within the same roaming profile. Please help me to solve this problem. I will be thankful to all for the help and support.
Best Answer by Expert techyv
Answered By 10 points N/A #101179
This could be a problem in the compatibility issues of the different operating system of your clients. These operating systems somehow in any way doesn't support some features of either of them because of innovation and fast upgrade of the systems' technology . But still there are solutions, of course that you can try for you to execute and perform the configuration of latest operating systems to connect with lower systems like Windows Server 2003.
You can try this one and review the steps one by one:
https://support.microsoft.com/en-us/help/926505/windows-small-business-server-2003-windows-7–windows-vista-and-outloo
I hope this can help.
Answered By 0 points N/A #101180
I thought so, it is compatibility issues of different operating system. I read a lot about this issue, finally i got the solution. Thanks Expert techyv for helping me.
